Favorite Scripts Zone
The Favorite Scripts zone lists the business process assistant (BPA) scripts that you have defined on your user preferences. You can click on a script to execute it. You can click the Search button in the zone to search for other scripts.
If you do not see the Favorite Scripts zone in your dashboard, navigate to User Menu and click the Preferences menu item to display the User - Portal Preferences page. Under the Dashboard Portal row, select the Display option for the Favorite Scripts zone.
