Warning If Unsaved Changes Exist
If you make any changes to an object and you don't commit these changes to the database, the following warning appears: "You have unsaved changes that will be lost if you continue. Press OK to continue anyway."
If you want to commit the changes, click Cancel. You will then return to the page and can make further changes or press Save. If you want to discard your changes and transfer to the new page, click OK.
CAUTION:
This warning is not displayed if you are working on a new object on a fixed page and you navigate to a different page. Information about new objects is preserved in memory in anticipation of your return to the page. For example, if you are in the middle of adding a new user and you want to quickly reference information on a different page, you will not receive the above warning because your information will be saved. If you use the back button to return to the user page, all of the information you were adding will be present and you can enter the rest of the new user's data.
Parent topic
