Maintaining Points
The Point portal is used to display and maintain points. Refer to
About Points for additional functional information.
You can access the portal by opening the menu, selecting Historian, and Point. A query portal opens with search options. After you select your record, the maintenance portal opens.
The following zone may appear as a part of the portal's Main tab page:
• Point- Displays the basic attributes of the point.
To define a point:
1. From the menu, select Historian, Point, and select Add.
2. Select a Point Type from the drop-down menu and click OK.
3. Complete all required fields. Notice, for the Point Identifier, Characteristics, and Point Relationship sections, you will see asterisks next to some fields. These fields are only required if you click the plus sign (+) to add these items. However, by default, these sections are optional.
4. Click Save to add the new point.
Parent topic
