Measurement Download to CSV
You use the Measurement Download to CSV portal to download measurement data to comma separated values (CSV) files for use in other systems.
To download measurement data:
1. Open the menu. Select Historian, and Download to CSV.
2. Select the source for the downloaded measurements from the Measurement Source drop-down list.
3. Define the date and time range for the downloaded data using the Start Date and End Date fields.
4. Search for and select one or more Point IDs for the downloaded data in the Point section
5. Click Download.
Parent topic
