Configuration Data
Configuration data is required to be shared between Oracle Utilities Opower and the third-party partner:
- Information that the third-party partner provides to Oracle Utilities Opower: Prior to Oracle Utilities Opower setting up integration, the third-party partner must provide the
redirect_urifor all applicable utilities and tiers relevant to the third-party partner. For a given utility and tier, this value is the URL that Oracle Utilities Identity and Access Management uses to return the authorization code. Identity and Access Management supports only a single URL, which must exactly match the one provided to the/authorizeendpoint when the authorization code flow is initiated. For example, aredirect_uriwould be of the formathttps://examplepartner.net/authenticate/redirect. -
Information that Oracle Utilities Opower provides to third-party partners for every
client and tier:
List of endpoints:
- The utility-specific OpenId Connect Discovery endpoint for the stage tier. Endpoints are of the format
https://idcs-[INSTANCE_ID_Stage].oraclecloud.com/.well-known/openid-configuration. - The utility-specific OpenId Connect Discovery endpoint for the production tier. Endpoints are of the format
https://idcs-[INSTANCE_ID_Production].oraclecloud.com/.well-known/openid-configuration.
Client credentials for a given utility and tier:
- client_id
- client secret
- Scope management: The list of scopes that are allowed for the given utility and tier.
List of endpoints:
