Getting Started
Oracle Utilities Live Energy Connect (LEC) V25.12.0.0 is a microservices architecture built using cloud-native tools and patterns and delivered as an on-premises solution. LEC V25.12.0.0 services run as a clustered application inside an Oracle Cloud Native Environment (OCNE) cluster. OCNE is a fully integrated suite for the development and management of cloud-native applications. The LEC v25.12.0.0 installer installs and deploys V25.12.0.0 resources and services on a running OCNE 2.x cluster. The LEC V25.12.0.0 installer currently supports a single-node OCNE cluster topology only.
Note: The term "node" in this document refers to a host being used in a Kubernetes cluster as a Kubernetes node. For more information about OCNE and Kubernetes terminology, refer to the OCNE documentation here: https://docs.oracle.com/en/operating-systems/olcne/
Oracle Utilities Live Energy Connect V25.12.0.0 must be installed on a system that is running an OCNE 2.x cluster. The Oracle Utilities Live Energy Connect V25.12.0.0 installer is distributed as a self-extracting TAR archive that will install product components (for example, configuration files, container images, Helm charts, and so on) to the running OCNE 2.x cluster. The TAR archive is installed from a machine that has network access to the running OCNE 2.x cluster (i.e., one that is running the OCNE 2.x CLI). If running a libvirt cluster, this will be the same host machine that the cluster is running on. For Bring Your Own model clusters, this will be a remote system with SSH access to the cluster.
