Installation Prerequisites
The following sections outline prerequisites that must be satisfied before installing Oracle Utilities Live Energy Connect (LEC) V25.12.0.0:
Hardware Requirements
The following are the minimum recommended hardware requirements for each host machine to be used in the OCNE cluster:
- CPU: 8 CPU
- Memory: 16 GB RAM
- Hard Disk Space:
- At least 40 GB available the
/vardirectory. - At least 256 GB available in the
/optdirectory.
- Architecture: x86-64
- Network Interface: 1 GB Ethernet NIC
- File System: The root file system should be XFS, which is the default Oracle Linux file system.
OCNE Cluster Creation
Oracle Utilities Live Energy Connect V25.12.0.0 must be deployed to a cluster created using the Oracle Cloud Native Environment 2.x CLI.
Note: LEC V25.12.0.0 currently only supports deployment to a single-node cluster.
See the following link for details on installing and deploying OCNE 2.x:
https://docs.oracle.com/en/operating-systems/olcne/
Additional Dependencies
The following software packages must be present on each cluster host machine prior to installing Oracle Utilities Live Energy Connect V8.0.0.2.0:
nginx: To install nginx, run the following shell command:
sudo dnf -y install nginx
sudo dnf -y install nginx-mod-stream
sudo setsebool -P httpd_read_user_content 1
sudo systemctl enable nginx
sudo systemctl start nginx
sudo mkdir -p /etc/nginx/conf.d/stream
helm: To install helm, run the following shell commands:
sudo dnf config-manager --enable ol9_olcne19
sudosd
yq: To install yq, run the following shell command (see https://github.com/mikefarah/yq):
sudo wget https://github.com/mikefarah/yq/releases/latest/download/yq_linux_amd64 -O /usr/bin/yq && sudo chmod +x /usr/bin/yq -
ocne and kubectl: These utilities should have been installed during the cluster install. For kubectl to run properly, add "export KUBECONFIG=$(once show)" to ~/.bashrc, and source that file. But, if not, see the ocne documentation to install it. And, if kubectl is not installed, use the following:
sudo dnf -y install kubectl
curl:This should be installed along with Oracle Linux, but verify.
jq: This should be installed along with Oracle Linux, but verify.
