1 Live Energy Connect Installation
The Oracle Utilities Live Energy Connect Installation Guide helps you understand the components and procedures necessary to install Live Energy Connect25.12.0.0.0.
Welcome to the Oracle Utilities Live Energy Connect (LEC) 25.12.0.0.0 Installation Guide. Use the information in this guide to understand the components and procedures for installing LEC.
Getting Started
Oracle Utilities Live Energy Connect 25.12.0.0.0 is a microservices architecture built using cloud-native tools and patterns and delivered as an on-premises solution. LEC 25.12.0.0.0 services run as a clustered application inside an Oracle Cloud Native Environment (OCNE) cluster. OCNE is a fully integrated suite for the development and management of cloud-native applications. The LEC 25.12.0.0.0 installer installs and deploys 25.12.0.0.0 resources and services on a running OCNE 2.x cluster. The LEC 25.12.0.0.0 installer currently supports a single-node OCNE cluster topology only.
The term "node" in this document refers to a host being used in a Kubernetes cluster as a Kubernetes node. For more information about OCNE and Kubernetes terminology, refer to the OCNE documentation.Oracle Utilities Live Energy Connect 25.12.0.0.0 must be installed on a system that is running an OCNE 2.x cluster. The Oracle Utilities Live Energy Connect 25.12.0.0.0 installer is distributed as a self-extracting TAR archive that will install product components (for example, configuration files, container images, Helm charts, and so on) to the running OCNE 2.x cluster. The TAR archive is installed from a machine that has network access to the running OCNE 2.x cluster (i.e., one that is running the OCNE 2.x CLI). If running a libvirt cluster, this will be the same host machine that the cluster is running on. For Bring Your Own model clusters, this will be a remote system with SSH access to the cluster.
