Hardware Requirements
Provides the Oracle Utilities Live Energy Connect host machine hardware requirements for use in an OCNE cluster.
The following are the minimum recommended hardware requirements for each host machine to be used in the OCNE cluster:
  • CPU: 8 CPU
  • Memory: 16 GB RAM
  • Hard Disk Space:
    • At least 40 GB available the /var directory.
    • At least 256 GB available in the /opt directory.
  • Architecture: x86-64
  • Network Interface: 1 GB Ethernet NIC
  • File System: The root file system should be XFS, which is the default Oracle Linux file system.
