OCNE Software Packages Dependencies
Oracle Utilities Live Energy Connect
25.12.0.0.0 requires the OCNE cluster to have preinstalled and
configured software packages (nginx, helm,
yq, ocne and kubectl),curl, and
jq.
The following software packages must be present on each cluster host machine prior to installing Oracle Utilities Live Energy Connect 25.12.0.0.0:
nginx: To install
nginx, run the following shell command:sudo dnf -y install nginx sudo dnf -y install nginx-mod-stream sudo setsebool -P httpd_read_user_content 1 sudo systemctl enable nginx sudo systemctl start nginx sudo mkdir -p /etc/nginx/conf.d/stream -
helm: To install
helm, run the following shell commands:sudo dnf config-manager --enable ol9_olcne19 sudosd -
yq: To install
yq, run the following shell command (see https://github.com/mikefarah/yq):sudo wget https://github.com/mikefarah/yq/releases/latest/download/yq_linux_amd64 -O /usr/bin/yq && sudo chmod +x /usr/bin/yq -
ocne and kubectl: These utilities should have been installed during the cluster install. For kubectl to run properly, add "
export KUBECONFIG=$(once show)" to~/.bashrc, and source that file. But, if not, see the ocne documentation to install it. And, if kubectl is not installed, use the following:sudo dnf -y install kubectl -
curl:This should be installed along with Oracle Linux, but verify.
jq: This should be installed along with Oracle Linux, but verify.
