Verifying the Oracle Utilities Live Energy Connect Installation
The Oracle Utilities Live Energy Connect 25.12.0.0.0 installation can be verified using the kubectl client CLI tool with the defined commands.
The Oracle Utilities Live Energy Connect 25.12.0.0.0 installation can be verified using the kubectl client CLI tool. To do this, run the following steps:
  1. Reload the user’s Bash environment variables by exiting the interactive shell and then starting a new one.
    Alternatively, you could run the command:
    source ~/.bashrc
  2. At the command prompt, check the status of all the pods in the “lec” namespace of the Kubernetes cluster by running the command:
    kubectl get pods -n lec
    This command should return a list of the LEC-specific pods in the cluster with information about their running status. If the installation was successful the status should say Running. The following is an example output:
    [lec@node ~]$ kubectl get pods -n
              lec
    NAME READY STATUS RESTARTS AGE
    fluentd-fld-fluentd-2g5qr 1/1 Running 1
              4m
    fluentd-fld-fluentd-knzfb 1/1 Running 1
              4m
    fluentd-fld-fluentd-m4fm7 1/1 Running 1
              4m
    kafka-0 1/1 Running 4 (58m ago) 3m
    kafka-zookeeper-0 1/1 Running 1 3m
    opensearch-cluster-master-0 1/1 Running 1
                5m
    os-dashboards-lec-747cdcd4cf-8874d 1/1 Running 1
                5m
    [lec@node ~]$
  3. For information about a specific pod use the ‘kubectl describe pod’ command:
    [lec@node ~]$ kubectl describe pod
              kafka-0
    Namespace: lec
    Priority: 0
    Service Account: kafka
    Node: node1/192.168.122.101
    Start Time: Wed, 27 Mar 2024 04:45:24
                +0000
    Labels:
              app.kubernetes.io/component=kafka
    app.kubernetes.io/instance=kafka
    app.kubernetes.io/managed-by=Helm
    app.kubernetes.io/name=kafka
    controller-revision-hash=kafka-57445667b
    helm.sh/chart=kafka-20.0.2
    statefulset.kubernetes.io/pod-name=kafka-0
    Annotations: <none>
    Status: Running
    IP: 10.244.0.20
    IPs:
    IP: 10.244.0.20
    Controlled By:
          StatefulSet/kafka
