Release 25.12.0.0.0
The Oracle Utilities Live Energy Connect Release Notes help you understand the enhancements, modifications, and known issues in the release.
Enhancements in the V25.12.0.0.0 Release
Oracle Utilities Live Energy Connect V25.12.0.0.0 provides enhancements to support Oracle Utilities Network Management SystemFlex SCADA and Edge DERMS features as well as core functionality. The main enhancements are described below.
Access to Logs through Configuration Manager
This feature adds the ability to view the line logs, via the OpenSearch feature, directly from the Configuration Manager.
Improved RTU Error and Status Reporting
This feature enhances the error information captured from the error/line logs that is then shared with Flex SCADA to provide users more detailed information when issues occur with RTU connections or when control requests fail.
Improved RTU Statistical Information Capture
This feature enhances the common statistical information captured for a communication channel to an RTU that is then shared with Flex SCADA. Based on configuration supplied in Flex SCADA, it will provide more information on polling periods and statistics with the ability to identify when a channel has failed.
Add Support for Single Channel, Multi-RTU Communication
This feature adds the ability to support DNP3 communications where multiple RTUs are configured on the same channel. Based on configuration supplied by Flex SCADA, RTUs on the channel will be polled in sequence to allow the capturing of events from the RTU before moving on to the next RTU.
