Demand Big Appliances Module
The Demand Big Appliance module educates customers about which appliances use the most electricity, and which are low-usage appliances. This information enables customers to understand how they can shift the usage of their appliances to reduce their energy use during peak hours. The module also lets customers know that they should avoid using multiple big appliances at the same time during peak hours to help reduce demand charges. The module includes illustrations of high-use appliances, including:
- Dryer
- Pool Pump
- Air Conditioner
- Dishwasher
Design
This image shows an exampl of the Demand Big Appliances module:
Figure 7-3 Demand Big Appliances Module
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Peak Period Name The name of the peak period can be configured in the heading and the high-energy insight statement. The same name should be used in all instances across all Load Shifting Rate Coach email modules. Default: Peak |
Required Choose one of the following: Use the default. Use the following peak period name: |
To see how this module fits into the overall user experience, see Design and Configuration: Demand Rate Coach.
