Demand Report Header Module
The Demand Report Header module notifies customers of when their demand hour occurred during the current month. This module is included only in the Demand Report email, and appears at the top, below the standard email header.
Design
This image shows an example of the Demand Report Header module:
Figure 7-7 Demand Report Header Module
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Peak Period Name The name of the peak period can be configured in the heading, the education statement, and the demand charge statement. The same name must be used in all instances in all Load Shifting modules. Default: Peak |
Required Required Choose one of the following:
To see how this module fits into the overall user experience, see Design and Configuration: Demand Rate Coach.
