Season Transition Module
The Season Transition module notifies customers when their peak to off-peak price ratios or peak hours are changing. This module is sent one week before the transition date, and again one week after the transition date, along with the regular cadence of the TOU Rate Coach emails. This module can be included in the Weekly Coach email or the Peak Usage Summary email, depending on the timing of the change.
Design
Pre-Transition Module
This image shows an example of the module:
Figure 7-30 Season Transition Module - Pre-Transition
Post-Transition Module
Figure 7-31 Seasonal Transition Module - Post-Transition
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Pre-Transition Subject Line Specify the subject line for emails that include the pre-transition module. Default: Hi [first name], your weekly Rate Coach has an update coming [date]. |
Required Choose one of the following:
Pre-Transition Header The header statement educates customers about an upcoming change to their TOU rate plan. While it is recommended to use the default heading, it is configurable to meet the needs of the utility. Default options:
Pre-Transition Insight Statement An insight message below the header describes the upcoming change. Depending on whether both peak price ratios and peak times are changing, the following default insight statements are used:
While it is recommended to use the default values, these can be configured to meet the needs of the utility. |
Post-Transition Subject Line Specify The subject line for emails that include the post-transition module. Default: Hi [first name], your weekly Rate Coach is here with new peak details. |
Post-Transition Header The header statement educates customers about a recent change to their TOU rate plan. It is recommended to use the default heading. Default: Here are the new peak hours and pricing. |
Post-Transition Insight Statement An insight message below the header describes the recent change. Depending on whether both peak price ratios and peak times are changing, the following default insight statements are used:
It is recommended to use the default values. |
Column and Row Labels in Pre-Transition and Post-Transition Tables It is possible to change the column and row labels (for example, Current, New, Dates, Peak Hours, Price Difference), to meet the needs of the utility. However, it is recommended that you use the default values, except where the name of the peak period needs to be updated to reflect the naming used by the utility. Default values for peak and partial-peak periods are Peak Hours and Partial Peak Hours. |
To see how this module fits into the overall user experience, see Design and Configuration: Time of Use Rate Coach.
User Experience Variations
This section discusses the user experience variations in the Season Transition module.
Peak Hours Change but Price Ratios Stay the Same
When only the peak hours are changing, and the ratios are staying the same, several items in the pre-transition and post-transition modules vary.
Pre-transition variations:
- Header: The module header is, "Coming soon: changes to peak hours."
- Insight Statement: The insight statement is, "Starting [date], peak hours will change for the new season. To save more, try to avoid using high-energy use appliances during peak hours."
- Peak Details Table: The table does not include the price difference row.
Post-transition variations:
- Header: The module header is, "Here are the new peak hours."
- Insight Statement: "As of [date], peak hours have changed for the new season. To save more, try to avoid using high-energy use appliances during peak hours."
Price Ratios Change but Peak Hours Stay the Same
When only the price ratios are changing, and the peak hours are staying the same, several items in the pre-transition and post-transition modules vary.
- Header: The module header is, "Coming soon: changes to peak pricing."
- Insight Statement: The insight statement is, "Starting [date], peak pricing will change for the new season. To save more, try to avoid using high-energy use appliances during peak hours."
- Peak Details Table: The table does not include the peak hours row.
- Header: The module header is, "Here is the new peak pricing."
- Insight Statement: "As of [date], peak pricing has changed for the new season. To save more, try to avoid using high-energy use appliances during peak hours."
Peak and Partial-Peak Hours Change but Price Ratios Stay the Same
When only the peak and partial-peak hours are changing, and the price ratios are staying the same, several items in the pre-transition and post-transition modules vary.
- Insight Statement: The insight statement is, "Starting [date], peak and partial-peak hours will change for the new season. To save more, try to avoid using high-energy use appliances during peak hours."
- Peak Details Table: The table includes a row for partial-peak hours and does not include the price difference row.
- Insight Statement: "As of [date], peak and partial-peak hours have changed for the new season. To save more, try to avoid using high-energy use appliances during peak hours."
Peak and Partial-Peak Hours and Price Ratios Change
When the peak and partial-peak hours are changing, and the price ratios are also changing, several items in the pre-transition and post-transition modules vary.
- Header: The module header is, "Coming soon: changes to peak hours and pricing."
- Insight Statement: The insight statement is, "Starting [date], peak and partial-peak hours will have new hours and pricing for the new season. To save more, try to avoid using high-energy use appliances during peak hours."
- Peak Details Table: The table includes a row for partial-peak hours.
- Header: The module header is, "Here are the new peak hours and pricing."
- Insight Statement: "As of [date], peak and partial-peak hours have changed to new hours and pricing for the new season. To save more, try to avoid using high-energy use appliances during peak hours."
