Configuring Contact Types
This portal is used to display and maintain a Contact Type.
Refer to Understanding Contact Types for more information.
You can access the portal by selecting Admin, then Usage, then Contact Type.
- Contact Type List: displays all of the Contact Types so you can choose the one you want to display in more detail
- Contact Type: shows the specific configuration for the selected Contact Type
