Configuring Usage Calculation Types
You use the Usage Calculation Type portal to maintain and view usage calculation types.
Refer to Understanding Usage Calculation Types for more information.
You can access the portal by selecting Admin, then Usage, then Usage Calculation Type.
- Usage Calculation Type List: This zone lists all usage calculation type records. Broadcast a record to display the details of the selected record.
- Usage Calculation Type: This zone displays details for the selected usage calculation type.
