Reverting Changes
Reverting changes will undo any changes you made since you checked out an object.
- Go to the object that you want to revert.
- Select Revert in the Revision Control sidebar zone.
- In the confirmation dialog box select OK to confirm the action or Cancel to return to the object page.
