Defining Asset Location Types
You use the Asset Location Type portal is used to display and maintain asset location types.
Refer to Understanding Asset Location Types for more information.
You can access the portal by selecting Admin, Location, then Asset Location Type.
- Asset Location Type List: This zone lists all asset location type records. Broadcast a record to display the details of the selected record.
- Asset Location Type: This zone provides information about the selected asset location type.
