Upgrading from Oracle Utilities Application Framework V4.3.0.3.0 to V4.3.0.4.0
New Tables
Table
Type of Table
F1_MIGR_REQ_INCL_REQ
Migration request Grouping
New Views
None
Dropped Tables
None
Unsupported Tables
None
Added Columns
Table
Column
Required
CI_BATCH_CTRL
APP_SVC_ID
Y
CI_XAI_RCVR_CTX
SEQNO
Y
CI_XAI_SNDR_CTX
SEQNO
Y
F1_IWS_SVC_ANN
SEQ_NUM
Y
F1_MIGR_REQ
MIGR_REQ_CAT_XFLG
N
F1_MIGR_REQ
MIGR_REQ_CLASS_FLG
Y
F1_MIGR_REQ_INSTR_ENTITY
COMMENT_LONG
N
EXT_REFERENCE_ID
N
Dropped Columns
Table
Column
CI_XAI_RCVR_CTX
CTXT_VAL
Unsupported Table Columns
None
Column Format Change
Table Name
Column Name
From
To
F1_EXT_LOOKUP_
VAL_CHAR
F1_EXT_LOOKUP_
VALUE
VARCHAR2
(30)
VARCHAR2
(254)
Primary Key Change
Table
Primary Key Columns
CI_XAI_RCVR_CTX
XAI_RCVR_ID, SEQNO
CI_XA_SNDR_CTX
XAI_SENDER_ID, SEQNO
