Operating Systems and Application Servers
This section details the operating system and application server combinations on which this version of Oracle Utilities Market Settlements Management is supported.
Application Server Operating Systems
• Oracle Linux 8.x for x86_64
• Oracle Solaris 11.4+ for SPARC (64-bit)
• IBM AIX 7.2. TL5+ for POWER (64-bit)
Prerequisite Application Server Software
• Oracle Database Client 12.1.0.x, 19.x
• Oracle Java SE Development Kit 1.8.0_291 (Windows, Solaris and Linux platforms only)
• IBM 64-bit SDK for AIX 8.0.0.x (IBM platforms only)
• Select jars from Hibernate ORM 4.1.0
• Oracle WebLogic Server 12c (Release 12.2.1.4) 64-bit
Notes:
Oracle Linux is 100% user space-compatible with Red Hat Enterprise Linux, therefore, Oracle Utilities Application Framework is also supported on Red Hat Enterprise Linux.
Refer to the Oracle Utilities Application Framework Database Administrator’s Guide for the Oracle database server requirements.
Refer to the
Certification Matrix for Oracle Utilities Products (Document ID 1454143.1) document on
My Oracle Support to determine if support for newer versions of the listed products have been added.
Please note the following:
• Version numbers marked with a “+” are the MINIMUM version supported. That version and all future 4th digit updates will be supported.
Example: Oracle 12.1.0.2+ means that 12.1.0.2 and any higher 12.1.0.x versions of Oracle are supported.
• An “x” indicates that any version of the digit designed by the “x” is supported.
Example: Linux 8.x indicates that any version of Linux 8 (8.0, 8.1, 8.2 etc) will be supported.
Windows Server
• Windows Server is not supported for Production environments. Wherever Windows Server is referenced within this guide, it is supported for Test or Development environments only.
WebLogic Server
• Oracle WebLogic Server (Fusion Middleware Infrastructure) Release 12.2.1.4
• Customers must download Oracle WebLogic Server from the Oracle Software Delivery Cloud.
Oracle Database Server
Prerequisite database server software (on any vendor supported platform where x is vendor supported version):
• Oracle Database Server Enterprise Edition 19c
• Oracle Database Server Standard Edition 2 19c
Oracle VM Support
This version of Oracle Utilities Market Settlements Management is supported on Oracle VM Server for x86 for supported releases of Oracle Linux and Microsoft Windows operating systems.
Refer to
My Oracle Support knowledge base article 249212.1 for Oracle’s support policy on VMWare.
Client Side Hardware Requirements
* The Recommended configuration supports better performance of the client.
** To reduce the amount of scrolling required for pages that are longer than 768 or 1024 pixels, consider placing a monitor into vertical position (with narrow side on the bottom).
Web Browser Requirements
The web browsers listed below are supported when used on each of the operating systems indicated:
