Before You Upgrade
For the list of operating system, application server and database server combinations that this Oracle Utilities Market Settlements Management version is certified to operate on, refer to
Supported Platforms and Hardware Requirements.
For further assistance, contact
My Oracle Support before you upgrade.
Note: If you are upgrading a previously installed application server, it is recommended that you make a backup before you start the upgrade procedure. The upgrade installation will remove your existing environment including your configurations.
