Conventions
This section contains several conventions to illustrate attributes and scope of configuration parameters:
• Each parameter has certain valid values. When applicable, the default value is indicated in bold.
• The scope of the parameter is indicated through the following terms for the applicable tiers
• The ordinality of the parameter is indicated. Parameters that are mandatory must exist and are set in the relevant configuration file for the product to operate.
