Parameter | com.ouaf.batch.jvmoptions |
Description | Custom JVM Options for submitter. Note: This setting can be overridden using the -z option on the submitjob.sh - Submit Batch Threads command line. |
Ordinality | Mandatory |
Valid Values | Valid JVM Options for the Java version used |
Source | Maintained by product templates. Use Configuring Batch Using Bedit to implement a different value. |
Applicability | Background Processing |
Example: | com.ouaf.batch.jvmoptions=-Xms1024k -Xmx2048k -XX:MaxPermSize=512m |
Parameter | com.splwg.grid.executionMode |
Description | Execution Mode used by process. Note: This setting can be overridden using the -e option on the submitjob.sh - Submit Batch Threads command line. |
Valid Values | [ CLUSTERED | THIN ] Note: The THIN mode is used by the Oracle Utilities SDK and should not be used outside that tool. |
Source | Maintained by product templates. Use Implementing Custom Templates to implement a different value. |
Example: | com.splwg.grid.executionMode=CLUSTERED |
Parameter | com.splwg.batch.submitter |
Description | Whether this execution can run without a threadpoolworker. Reserved for development of batch using the Oracle Utilities SDK. If set to true then, com.splwg.grid.executionMode - Online Execution Mode must be set to THIN. |
Valid Values | [false|true] |
Source | Maintained by product templates for LOCAL submission. |
Example: | com.splwg.batch.submitter=true |
Parameter | com.splwg.batch.submitter.batchCd |
Description | Batch Code for bbatch specific configuration. This setting should not be set in the global submitbatch.properties file. Note: This setting should only be set in configuration files for testing purposes. In other situations the -b option on the submitjob.sh - Submit Batch Threads command line should be used. |
Valid Values | Batch Code |
Source | Maintained by product templates for submission. |
Example: | com.splwg.batch.submitter.batchCd=QABATCH |
Parameter | com.splwg.batch.submitter.distThreadPool |
Description | Name of pool to be used for batch process. If threadpoolworker not used then LOCAL must be specified. This can be set globally and at the individual batch job level. Note: This setting can be overridden using the -p option on the submitjob.sh - Submit Batch Threads command line. |
Valid Values | Default: DEFAULT |
Example: | com.splwg.batch.submitter.distThreadPool=DEFAULT |
Parameter | com.splwg.batch.submitter.languageCd |
Description | Language code used for messages for execution of background process. Relevant language pack must be installed. Note: This setting can be overridden using the -l option on the submitjob.sh - Submit Batch Threads command line. |
Valid Values | Default: ENG |
Example: | com.splwg.batch.submitter.languageCd=ENG |
Parameter | com.splwg.batch.submitter.maximumCommitRecords |
Description | Commit Interval used for execution. This is the number of objects processed per work unit. Note: This setting can be overridden using the -f option on the submitjob.sh - Submit Batch Threads command line. |
Valid Values | Job specific |
Example: | com.splwg.batch.submitter.maximumCommitRecords=200 |
Parameter | com.splwg.batch.submitter.promptForValues |
Description | Prompt for value when running in interactive mode. This is primarily used for developers who are testing their job manually. Note: Implementers should only use the true value if executing jobs from the Oracle Utilities SDK. |
Valid Values | [true|false] |
Example: | com.splwg.batch.submitter.promptForValues=false |
Parameter | com.splwg.batch.submitter.processDate |
Description | Business Date for batch process. This setting should not be set in the global submitbatch.properties file. Note: This setting should only be set in configuration files for testing purposes. In other situations the -d option on the submitjob.sh - Submit Batch Threads command line should be used. |
Valid Values | Business Date in ISO YYYY-MM-DD format |
Example: | com.splwg.batch.submitter.processDate=2015-03-08 |
Parameter | com.splwg.batch.submitter.rerunNumber |
Description | Rerun Number to be used for execution. Note: Only batch controls that support rerun numbers are supported with this configuration setting. Note: This setting can be overridden using the -r option on the submitjob.sh - Submit Batch Threads command line. |
Ordinality | Optional |
Valid Values | Valid run number. A value of zero (0) denotes disables this setting. |
Example: | com.splwg.batch.submitter.rerunNumber=56 |
Parameter | com.splwg.batch.submitter.softParameter |
Description | For any program-specific parameters, use this form of property specification in the format: com.splwg.batch.submitter.softParameter.<parmname>=<value> The <parmname> denotes the name of the parameter. For example, to specify a number of rows to skip in <value> when submitting a validation program: com.splwg.batch.submitter.softParameter.SKIP-ROWS=1000 Multiple soft parameters may be specified. Note: This setting can be overridden using the -x or -X options on the submitjob.sh - Submit Batch Threads command line. |
Valid Values | Valid value for parameter |
Example: | com.splwg.batch.submitter.softParameter.SKIP-ROWS=1000 |
Parameter | com.splwg.batch.submitter.threadCount |
Description | Thread limit used for execution. Note: Only batch controls that support multithreaded are supported with this configuration setting. Note: This setting can be overridden using the -c option on the submitjob.sh - Submit Batch Threads command line. |
Valid Values | Valid thread limit. A value of one (1) is used for single threaded jobs. Default: 1 |
Example: | com.splwg.batch.submitter.threadCount=1 |
Parameter | com.splwg.batch.submitter.threadNumber |
Description | Individual thread number used for execution. Note: This setting can be overridden using the -t option on the submitjob.sh - Submit Batch Threads command line. |
Valid Values | Valid thread number. The value must be less than or equal to the com.splwg.batch.submitter.threadCount - Thread Limit. A value of zero (0) spawns multiple threads up to the limit expressed in com.splwg.batch.submitter.threadCount - Thread Limit. Default: 0 |
Example: | com.splwg.batch.submitter.threadNumber=0 |
Parameter | com.splwg.batch.submitter.traceProgramEnd |
Description | Enables or disables tracing for the end of the program. Note: This setting is designed for developers and for support purposes. Note: This setting can be overridden using the -g option on the submitjob.sh - Submit Batch Threads command line. |
Example: | com.splwg.batch.submitter.traceProgramEnd=false |
Parameter | com.splwg.batch.submitter.traceProgramStart |
Description | Enables or disables tracing for the start of the program. Note: This setting is designed for developers and for support purposes. Note: This setting can be overridden using the -g option on the submitjob.sh - Submit Batch Threads command line. |
Example: | com.splwg.batch.submitter.traceProgramStart=false |
Parameter | com.splwg.batch.submitter.traceSQL |
Description | Enables or disables tracing of ALL SQL statements executed by the program. Note: This setting is designed for developers and for support purposes. Note: This setting can be overridden using the -g option on the submitjob.sh - Submit Batch Threads command line. |
Example: | com.splwg.batch.submitter.traceSQL=false |
Parameter | com.splwg.batch.submitter.traceStandardOut |
Description | Enables or disables tracing of ALL in-program debug statements executed by the program. Note: This setting is designed for developers and for support purposes. Note: This setting can be overridden using the -g option on the submitjob.sh - Submit Batch Threads command line. |
Example: | com.splwg.batch.submitter.traceStandardOut=false |
Parameter | com.splwg.batch.submitter.userId |
Description | Userid used by job to check authorization to underlying application services. Note: This setting can be overridden using the -u option on the submitjob.sh - Submit Batch Threads command line. |
Valid Values | Valid userid. Note: The SYSUSER account should not be used for non-demonstration environments. |
Example: | com.splwg.batch.submitter.userId=USER01 |
Parameter | spl.runtime.batch.L2CacheMode |
Description | Defines the 2nd-level cache mode. Valid values are READ_ONLY (default), READ_WRITE or OFF. READ_ONLY is for performance as it loads the configuration entities into the 2nd-level (JVM-level) cache and accesses them from there only. In READ_ONLY mode, the cached entities may not be updated. READ_WRITE also loads them into the L2 cache, but they can be updated. The drawback is that an update of a cached entity hits both the database and cache as it gets updated in both places. In OFF mode the 2nd-level cache is completely disabled. Some jobs, for example LDAP import (F1-LDAP), need to update some of these entities (e.g. User), so it requires the L2 cache to be either OFF or READ_WRITE. The choice between OFF and READ_WRITE depends on requirement; the effect is the same. Note: This setting can be overridden using the -l2 option on the submitjob.sh - Submit Batch Threads command line. |
Valid Values | [READ_ONLY|READ_WRITE|OFF] |
Example: | spl.runtime.batch.L2CacheMode=READ_ONLY |
Parameter | tangosol.coherence.distributed.localstorage |
Description | Sets whether data is cached local or not. This is used to optimize large networks of submitters and threadpools with cache nodes. |
Example: | tangosol.coherence.distributed.localstorage=false |
Parameter | tangosol.coherence.role |
Description | Sets role of Submitter. Informational information on JVM used for monitoring purposes only. |
Valid Values | Generated with the name OUAF_<batchcode>_Submitter where <batchcode> is the Batch Control identifier for the batch job. |
Example: | tangosol.coherence.role=OUAF_QABATCH_Submitter |
