Directory | Contents |
bin | Utilities and commands for operations and configuration. |
etc | A set of directories holding configuration files used in Oracle Utilities Market Settlements Management as well as template files and base libraries used to generate the configuration files. |
java | Location of temporary files for Java execution. |
ks | Location of Key Stores. |
oem | Application Management Suite for Oracle Utilities generated files. Note: Files in this directory are generated by the discovery process used with the Oracle Application Management Pack for Oracle Utilities. |
logs | Location of Oracle Utilities Market Settlements Management specific log files. |
osbapp | Oracle Service Bus integration (optional). |
product | Directories containing any bundled software with the product. |
scripts | Directory containing any implementation specific scripts. |
soaapp | Oracle SOA integration (optional). |
splapp | Directories containing the JEE web applications (see Software (splapp) Directory). |
structures | Internal structures used for configuration utilities. |
templates | Base templates used to build configuration files. |
tmp | Directory used to hold intermediary files used for the deployment process. |
tools | Location of service pack, single fix and group fix utilities (see Tools Directory). |
updates | Location of installed_fixes.txt Note: The updates directory only exists after at least one patch has been installed. If the directory does not exist, then no patches have been installed on this environment. |
applications | Location of the web application product files. |
billView | Location of the online bill viewing files (products supporting bill view only). |
businessapp | Location of the business application product files. |
certs | Location of security certificates. |
config | Location of temporary configuration files. |
iws | Location of native web services. |
ohelpsource | Oracle Help engine source location. |
pending | Internal use only. |
standalone | Location of common Java libraries and the batch component of the product. |
tpw | Location of threadpool worker specific files. |
xmlMetaInfo | Location of the service definitions for the product. |
bin | General Software patching utilities. |
bin/db | Database Patching utilities. |
bin/db/bin | Binaries for patching. |
bin/db/config | Logging configuration for patching utilities. |
bin/db/lib | Java Libraries for patching utilities. |
domaintemplates | Oracle WebLogic Domain Templates for product. |
Directory/files | Owner | Group | Other |
etc | rwx | r-x | --- |
Individual files | rw- | r-- | --- |
logs | rwx | rwx | --- |
logs/system | rwx | rwx | --- |
Individual log files | rw- | r-- | --- |
Oracle WebLogic Configuration Files | rw- | r-- | --- |
Oracle WebLogic shell scripts (.sh) | rwx | r-x | --- |
product | rwx | r-x | --- |
product/apache-ant/bin/ant | rwx | r-x | --- |
scripts, tools, updates | rwx | r-x | --- |
Shell scripts (.sh) in bin | rwx | r-x | --- |
osbapp, soaapp, splapp | rwx | r-x | --- |
structures | rwx | r-x | --- |
templates | rwx | r-x | --- |
tmp | rwx | r-x | --- |
