Aggregation Master Configuration
The Aggregation Master Configuration defines common parameters used with aggregation processing, including:
Batch Controls used by the dimension scan and aggregation process, for both scheduled and adhoc execution.
Details for how the system compares interval and billing data for the same set of customers in order to use only one source or other.
