Configuring Service Point Types
You use the Service Point Type portal to view and maintain service point types.
You can access the portal by selecting Admin, Device Installation, Service Point Type.
If the Restrict Division setting in the Control by Division section in the MDM Master Configuration is set to "Yes", this zone displays only unsecured service point types as well service point types with a Division (or Divisions) associated with the user on the User Miscellaneous Information zone on the Miscellaneous tab of the User portal.
Service Point Type List: This zone lists all service point type records. Broadcast a record to display the details of the selected record.
Service Point Type: This zone provides information about the selected service point type.
Valid Field Task Types: This zone lists the field task types considered valid for the selected service point type.
Valid Disconnect Location: This zone lists disconnection locations considered valid for the selected service point type.
