Configuring Usage Transaction Exception Types
This portal is used to display and maintain a Usage Transaction Exception Type.
You can access the portal by selecting Admin, then Usage, then Usage Transaction Exception Type.
• Usage Transaction Exception Type List: displays all of the Usage Transaction Exception Types so you can choose the one you want to display in more detail
• Usage Transaction Exception Type: shows the specific configuration for the selected Usage Transaction Exception Type
Parent topic
