Field / Section | Value | ||||
Data Source | CM-E-KWH-60-TRANS | ||||
Description | Electric kWh 60min Transformer Interval Measurements | ||||
Status | Active | ||||
Data Source Class | Measurements from US Service Points | ||||
Interval / Scalar | Interval | ||||
Sourced Measuring Component Type |
Data Source | CM-G-CCF-60-FACIL | ||||
Description | Gas CCF 60min Facility Interval Measurements | ||||
Field / Section | Value | ||||||
Measuring Component Type | CM-E-I-AGG-KWH-60-TRANS | ||||||
Description | Electric - Interval - Aggregation - kWh 60min Transformer Load | ||||||
Measuring Component Business Object | Dynamic Aggregator - Interval (D1-AggregatorInterval) | ||||||
Measurement Business Object | Aggregation Measurement (D1-AggregationMeasurement) | ||||||
Measuring Component Class | Aggregator | ||||||
Service Type | Electric | ||||||
Allow Negative Consumption | Allowed | ||||||
Consumptive/Subtractive | Consumptive | ||||||
Interval Size | 01:00:00 | ||||||
Data Source | Electric kWh 60min Transformer Interval Measurements | ||||||
Value Identifiers |
Field / Section | Value | ||||||||||||||||||||||||||||||
Measuring Component Type | CM-G-I-AGG-CCF-60-FACIL | ||||||||||||||||||||||||||||||
Description | Gas - Interval - Aggregation - CCF 60min Downstream | ||||||||||||||||||||||||||||||
Measuring Component Business Object | Dynamic Aggregator - Interval (D1-AggregatorInterval) | ||||||||||||||||||||||||||||||
Measurement Business Object | Aggregation Measurement (D1-AggregationMeasurement) | ||||||||||||||||||||||||||||||
Measuring Component Class | Aggregator | ||||||||||||||||||||||||||||||
Service Type | Gas | ||||||||||||||||||||||||||||||
Allow Negative Consumption | Allowed | ||||||||||||||||||||||||||||||
Consumptive/Subtractive | Consumptive | ||||||||||||||||||||||||||||||
Interval Size | 01:00:00 | ||||||||||||||||||||||||||||||
Data Source | Gas CCF 60min Facility Interval Measurements | ||||||||||||||||||||||||||||||
Value Identifiers |
Aggregation Group | CM-E-CONS-TRANS | ||||||||
Description | Electric Dynamic Consumption | ||||||||
Status | Finalized | ||||||||
Aggregation Category | Analytics | ||||||||
Time Zone | US Pacific Time | ||||||||
Aggregation Schedule | • Aggregation Schedule Type: Defined Lag • Aggregation Cut-Off Time: 0:00:00 • Aggregation Horizon: 24:00:00 • Aggregation Lag: 48:00:00 | ||||||||
Aggregation Measuring Component Sets |
Aggregation Group | CM-E-CONS-PROF | ||||||||
Description | Consumption - Profile Class | ||||||||
Time Zone | |||||||||
Aggregation Group | CM-G-LOSS | ||||||||
Description | Gas Dynamic Consumption | ||||||||
Measuring Component Set | CM-E-CONS-TRANS | ||||||||||||||||||||
Status | Active | ||||||||||||||||||||
Description | Electric - Consumption - Transformer - Interval | ||||||||||||||||||||
Measuring Component Type | Electric - Interval - Aggregation - kWh 60min Transformer Load | ||||||||||||||||||||
Aggregation Group | Electric Dynamic Consumption | ||||||||||||||||||||
Measuring Component Set Class | Aggregation Foundation | ||||||||||||||||||||
Allow Partial Constituent Aggregation | Yes | ||||||||||||||||||||
Extract | Do Not Extract | ||||||||||||||||||||
General Processing | |||||||||||||||||||||
Criteria Processing | • Non-Individually Managed Formula: TFORM | ||||||||||||||||||||
Dimensions |
Criteria | • Criteria Name: TFORM • Source Type: Table (Demo) • Source Entity: Service Point Facility - MDM • Column/Type: Facility Relationship Type • Criteria Type: Include • Value: Commodity Distribution |
Measuring Component Set | CM-E-CONS-PROF | ||||||||||||||||||||
Description | Consumption - Profile Class - Interval | ||||||||||||||||||||
Aggregation Group | Consumption - Profile Class | ||||||||||||||||||||
General Processing | • Sequence: 10 • Initiation Method: Manual • Imported from External Source: No | ||||||||||||||||||||
Criteria Processing | |||||||||||||||||||||
Dimensions |
Criteria |
Measuring Component Set | CM-G-LOSS | ||||||||||||||||||||
Description | Gas - Consumption - Downstream - Interval | ||||||||||||||||||||
Measuring Component Type | Gas - Interval - Aggregation - CCF 60min Downstream | ||||||||||||||||||||
Aggregation Group | Gas Dynamic Consumption | ||||||||||||||||||||
Criteria Processing | Non-Individually Managed Formula: TFORM | ||||||||||||||||||||
Dimensions |
