Recommendations for Creating an On-Premises Production Environment
Oracle recommends that you do not clone the demonstration environment as a basis for a new production environment. The demonstration environment typically includes transactional data that will be irrelevant to your production environment and can cause unexpected issues if it is not purged correctly. The recommended process is to start a new production environment from a new installation and migrate "clean" system data (such as business objects and algorithms) and administrative data (such as sample activity types or other administrative entities) from the demonstration and/or test or development environments as applicable.
Your implementation can use bundling and/or the Content Migration Assistant to move system and administrative data. Instructions for using these tools are contained in the
Bundling and
Content Migration Assistant sections in the Oracle Utilities Application Framework
Administrative User Guide.
Contact
Oracle customer support if further assistance is required.
Parent topic
