Cloud Service Test Harness
The Smart Grid Gateway Cloud Service Test Harness is used to simulate a head end system for testing smart meter commands in a cloud implementation.
The test harness is "stateless", meaning it does not store meters or their current status. The harness is designed to return a successful result to all command requests by default. Devices must be created in a specific manner to return an error.
How the Test Harness Works
The test harness includes SOAP web service implementations for each command supported by the various Smart Grid Gateway adapters. The Test Harness's container is managed by Oracle cloud services and internal routing definitions allow web service requests to locate the proper container without requiring users to update ports or other configurations. There is no user-accessible configuration required for the test harness itself.
Creating Devices for use with the Test Harness
The test harness works with any sort of device capable to sending smart meter commands. By default, all commands are successful.
Devices must be created in a specific manner in order for errors to be returned from the test harness. Specifically, commands for devices whose identifiers (badge number, serial number, internal meter number, pallet number, external ID, MDM external ID, and asset ID) end in "ERR" will return an error. This means that when setting up devices for testing via the test harness, you must create separate devices for successful and unsuccessful (error) results.
The simplest approach when creating "error" devices is to use the same identifier value for all identifiers, but at a minimum, "ERR" MUST be the final part of the identifier value for the AMI Device ID Type and AMI Pre-Commissioning Device ID Type configured on the head end system.
Defining Head End Systems, Processing Methods, Outbound Message Types, and Message Senders for use with the Test Harness
This section provides guidelines for creating data and records used with smart meter commands when using the test harness.
Head End System
When configuring a head end system for use with the test harness, note the identifier types specified in the AMI Device ID Type and AMI Pre-Commissioning Device ID Type fields. When creating devices intended to return an error, the identifier values for the identifier type(s) specified for these fields MUST end in "ERR" to return an error from the test harness.
When creating outbound message types for use with the test harness, use the appropriate outbound business object based on the specific command. See
Smart Meter Command Flows for details.
Message Senders
When creating message senders for use with the test harness, use the following settings:
Main tab:
• Invocation Type: Real-Time
• Message Class: SOAPSNDR
• Active: <checked>
• Msg Encoding: UTF-8 message encoding
Context tab:
• HTTP Header: soapAction: <soapaction>
Note the format used here is:
SoapAction: {URI}
That's using a colon, followed by a space between the SoapAction and the value. You cannot use an equals (=) sign. For example:
SoapAction: http://www.multispeak.org/Version_4.1_Release/MeterAddNotification
• HTTP Login User: A user which has been assigned to the SGGHarnessUser role in Oracle Identity Cloud Service (IDC).
• HTTP Login Password: The password for the user above.
• HTTP Method: POST
• HTTP URL 1: <endpoint_URL>
@SGGTEST@<adapter_name>/<webservice>
where:
◦ @SGGTEST@ is a token that combines the protocol, host, port, tenant, domain, and application
◦ <adapter_name> is one “lg”, “itron”, “ssn”, or “sensus”, as appropriate
External Systems
When creating outbound message types on external systems and for use with the test harness, be sure to specify the appropriate Message XSL and Response XSL files based on the outbound message business object. See
Creating an External System for lists of these files.
Processing Methods
Command processing methods for a head end system used with the test harness should reference an Outbound Message Type, either the Default Outbound Message Type or an Outbound Message Type for a specific Device Type.
Parent topic
