Native Implementation Configuration Checklists
This section provides an overview of the steps involved in configuring Native implementations of Oracle Utilities Smart Grid Gateway adapters, including
Payload Processing and
Smart Meter Command Processing.
Payload Processing Checklist
5. Configure Processing Methods for the Head End System appropriate for payload processing, including.
◦ Initial Measurement Creation
◦ Device Event Mapping
◦ UOM Translation
7. Configure the adapter's Master Configuration (if appropriate). See
Master Configurations for more information.
Smart Meter Command Processing Checklist
1. Configure Activity Types for each command you wish to support in your implementation. Smart meter commands are activities in the system. For each command you plan to support, confirm that you have a corresponding Activity Type configured.
2. Configure Communication Types appropriate for each command you wish to support in your implementation. Each communication sent to the head end system as part of a command request requires a communication type. See the following sections for more information about the specific communications used with each command:
Note: Most Adapters use outbound communications only.
5. Configure an External System to represent the Head End System.
6. Configure a Head End System to represent the Head End System. Head End Systems reference the corresponding External System. See
Creating Head End Systems for more information.
7. Configure Processing Methods for the Head End System appropriate for each command you wish to support in your implementation. See
Configuring Processing Methods for more information.
9. Configure the adapter's Master Configuration (if appropriate) See
Configuration Details Reference
Refer to Knowledge Base article
2785031.1 on
My Oracle Support for a spreadsheet containing configuration details for the following Adapters:
• Itron OpenWay
• Silver Spring Networks
• Landis+Gyr
• MV90 (Payload Processing Only)
This spreadsheet contains lists of configuration objects used by each adapter, including:
• Activity Types
• Communication Types
• Message Senders
• Head End System
• Outbound Message Type
• External System
• Master Configurations (as applicable)
• Extendable Lookups
• Batch Controls
Parent topic
