Command | Outbound Message Type / Business Object | “Result” Outbound Message Type / Business Object |
Device Commissioning | Itron - Add Meter Definitions O/B Msg Type (D8-AMDOBM) Itron - Commissioning Outbound Message (D8-ItronCommissionOutboundMsg) | N/A |
Device Decommissioning | Itron - Deregister Meter O/B Msg Type (D8-DREGOBM) Itron - Decommissioning Outbound Message (D8-ItronDecommissionOutbndMsg) | N/A |
Remote Connect | Itron - Reconnect Meter O/B Msg Type (D8-RCNOBM) Itron - Remote Connect Outbound Message (D8-ItronRemoteConnectOutbndMsg) | Itron - Get Reconnect Meter Result O/B Msg Type (D8-GRCNOBM) Itron - Get Remote Connect Results Outbound Message (D8-ItronRemoteCntRsltOutMsg) |
Remote Disconnect | Itron - Disconnect Meter O/B Msg Type (D8-DISCOMOBM) Itron - Disconnect Outbound Message (D8-ItronRemoteDisconnectOutMsg) | Iron - Get Disconnect Meter Result O/B Msg Type (D8-GDMROBM) Itron - Get Disconnect Result Outbound Message (D8-ItronRemoteDcntRsltOutMsg) |
On-Demand Read (Scalar) | Itron - Contingency Read O/B Msg Type (D8-CRDOBM) Itron - Contingency Read Outbound Message (D8-ItronOnDemandReadOutbndMsg) | Itron - Get Contingency Read Results O/B Msg Type (D8-GCRDOBM) Itron - Get Contingency Read Result Outbound Message (D8-ItronOnDemandReadRsltOBMsg) |
On-Demand Read (Interval) | Itron - Contingency Read O/B Msg Type (D8-CRDOBM) Itron - Contingency Read Outbound Message (D8-ItronOnDemandReadOutbndMsg) | Itron - Get Contingency Read Results O/B Msg Type (D8-GCRDOBM) Itron - Get Contingency Read Result Outbound Message (D8-ItronOnDemandReadRsltOBMsg) |
Scheduled Read (Scalar) | Itron - Scheduled Read O/B Msg Type (D8-SROBM) Itron - Schedule Read Outbound Message (D8-ItronInterrogateByGrpOBMsg) | Itron - Get Scheduled Read Result O/B Msg Type (D8-GSRROBM) Itron - Get Schedule Read Result Outbound Message (D8-ItronInterrogateByGrpRsltOB) |
Scheduled Read (Interval) | Itron - Scheduled Read O/B Msg Type (D8-SROBM) Itron - Schedule Read Outbound Message (D8-ItronInterrogateByGrpOBMsg) | Itron - Get Scheduled Read Result O/B Msg Type (D8-GSRROBM) Itron - Get Schedule Read Result Outbound Message (D8-ItronInterrogateByGrpRsltOB) |
Device Status Check | Itron - Ping By Endpoints O/B Msg Type (D8-DSCOBM) Itron - Device Status Check Outbound Message (D8-ItronDvcStatusChkOutbndMsg) | Itron - Get Ping By Endpoints Result O/B Msg Type (D8-GDSCROBM) Itron - Get Device Status Check Result Outbound Message (D8-ItronDvcStatusChkRstlOBMsg) |
Multi-Device Status Check | Itron - Multi Ping By Endpoints O/B Msg Type (D8-MDSCOBM) Itron - Multi Device Status Check Outbound Message (D8-ItronDvcStChkMtDvcOutbndMsg) | Itron - Get Multi Ping By Endpoints Result O/B Msg Type (D8-GMDSCOBM) Itron - Get Multi Device Status Check Result Outbound Message (D8-ItronDvcStChkMtDvcRsltOBMsg) |
Load Check | Itron - Detect Load Side Voltage O/B Msg Type (D8-DLSVOBM) Itron - Detect Load Side Voltage Outbound Message (D8-ItronDetectLoadSideVolOBMsg) | Itron - Get Detect Load Side Voltage Results O/B Msg Type (D8-GDLSVOBM) Itron - Get Detect Load Side Voltage Result Outbound Message (D8-ItronDetLSVoltMtrRsltOutMsg) |
Device Commissioning | Add Meter to Inventory (L+G) (D3-AMIOMTYP) LG - Add Meter To Inventory OB Message (D3-AddMeterToInventoryOBMsg) |
Device Decommissioning | Notify Remove Meter (L+G) (D3-MRENOMTYP) LG - Meter Remove Notification OB Message (D3-MeterRemoveNotifOBMsg) |
Meter Retire | Notify Retire Meter (L+G) (D3-MRNOMTYP) LG - Meter Retire Notification OB Message (D3-MeterRetireNotifOBMsg) |
Meter Exchange | Notify Exchange Meter (L+G) (D3-MENOBMTYP) LG -Meter Exchange Notification OB Message (D3-MeterExchNotificatnOBMsg) |
Remote Connect | Initiate Connect Disconnect by Meter Number (L+G) (D3-INCODIOBM) LG Initiate Connect Disconnect OB Message (D3-InitConnectDisconnectOBMsg) |
Remote Disconnect | Initiate Connect Disconnect by Meter Number (L+G) (D3-INCODIOBM) LG Initiate Connect Disconnect OB Message (D3-InitConnectDisconnectOBMsg) |
Demand Reset | Schedule Demand Reset (L+G) (D3-SDROMTYP) LG - Schedule Demand Reset OB Message (D3-ScheduleDemandResetOBMsg) |
On-Demand Read (MultiSpeak) | Initiate Read by Meter Number (L+G) (D3-INMRMNOBM) L+G MultiSpeak InitiateMeterReadByMeterNumber OB Message (D3-InitMtrReadByMtrNumOBMsg) |
On-Demand Read (Interval) [CIM] | Initiate On-Demand Read (CIM L+G) (D3-CIMODR) CIM AMIRequest GetMeterReads OB Message (D3-CIMAMIRequestGetMtrRdOBMsg) |
On-Demand Read (Scalar) [CIM] | Initiate On-Demand Read (CIM L+G) (D3-CIMODR) CIM AMIRequest GetMeterReads OB Message (D3-CIMAMIRequestGetMtrRdOBMsg) |
Device Status Check | Initiate Device Status Check (CIM L+G) (D3-CIMDSC) CIM AMIRequest GetMeterReads OB Message (D3-CIMAMIRequestGetMtrRdOBMsg) |
Device Commissioning | Notify Add Meter (Sensus) (D6-SMANOMTYP) Sensus - Meter Add Notification OB Message (D6-MeterAddNotificationOBMsg) |
Device Decommissioning | Notify Remove Meter (Sensus) (D6-SMRNOMTY) Sensus -Meter Remove Notification OB Msg (D6-MeterRemoveNotificatnOBMsg) |
Remote Connect | Initiate Connect Disconnect by Meter Number (Sensus) (D6-INCODIOBM) Sensus Initiate Connect Discon OB Message (D6-InitConnectDisconnectOBMsg) |
Remote Disconnect | Initiate Connect Disconnect by Meter Number (Sensus) (D6-INCODIOBM) Sensus Initiate Connect Discon OB Message (D6-InitConnectDisconnectOBMsg) |
On-Demand Read (MultiSpeak) | Initiate Read by Meter Id (Sensus) (D6-SIMROMTY) Sensus - Initiate Meter Read By MtrID OBMsg (D6-InitMtrRdMtrIdOBMsg) |
Device Status Check | Initiate Outage Detection (Sensus) (D6-SIODTOMTY) Sensus InitiateOutageDetection OB Message (D6-InitOutageDetectionOBMsg) |
Device Commissioning | Replace Location (Commission SSN) (D7-RLOCOBMTY) SSN - Replace Location (Comm) Outbound Message (D7-ReplaceLocationOBMsg) | N/A |
Device Decommissioning | Replace Device (Decommission SSN) (D7-RDVCOBMTY) SSN - Replace Device At Loc O/B Message (D7-ReplaceDeviceAtLocOBMsg) | N/A |
Remote Connect | Connect Disconnect Device (SSN) (D7-CDCOBMTYP) SSN - Connect Disconnect OB Message (D7-ConnectDisconnectOBMsg) | Get Connect Disconnect Result (SSN) (D7-GCDROBMTY) SSN - GetConnectDisconnectResult OB Message (D7-GetCntDiscntResultOBMsg) |
Remote Disconnect | Connect Disconnect Device (SSN) (D7-CDCOBMTYP) SSN - Connect Disconnect OB Message (D7-ConnectDisconnectOBMsg) | Get Connect Disconnect Result (SSN) (D7-GCDROBMTY) SSN - GetConnectDisconnectResult OB Message (D7-GetCntDiscntResultOBMsg) |
On-Demand Read (Scalar) | Add Scalar Read Job (SSN) (D7-AMRJSCOBT) SSN - Add Meter Read Job Scalar OB Message (D7-AddMeterReadJobScalarOBMsg ) | Get Scalar Read Results by Job Id (SSN) (D7-GMRRBJOMT) SSN - GetMeterReadResults(Scalar) OB Message (D7-GetSclrMtrRdRstByJobIdOBMsg ) |
On-Demand Read (Interval) | Add Interval Read Job (SSN) (D7-AMRJINOBT) SSN - AddMeterReadJob Interval OB Message (D7-AddMtrReadJobIntervalOBMsg ) | Get Interval Read Results by Job Id (SSN) (D7-GIMRRJOMT) SSN - GetMeterReadResults(Interval) OB Message (D7-GetIntMtrRdRsltByJobIdOBMsg ) |
Device Status Check | Add Meter Ping Job (SSN) (D7-APJOBM) SSN - Add Ping Job OB Message (D7-AddPingJobOBMsg) | Get Device Ping Job Results (SSN) (D7-GPJROM) SSN - Get Ping Results O/B Message (D7-GetPingResultsOBMsg) |
