Understanding Settlement Subscription Types
Settlement subscription types are collections of properties defining a class of settlement subscriptions. Settlement subscription types also control valid values for various attributes of settlement subscriptions.
Settlement subscription types are defined by:
Transaction Business Object: The business object used for settlement transactions based on settlement subscriptions of this type
Default Recipient: The recipient that will be defaulted for settlement subscriptions of this type. A settlement subscription’s recipient dictates the system to which results of settlement transactions are sent.
Transaction Retention Mode: Defines how settlement transactions based on settlement subscriptions of this type are retained. "Keep All" indicates that all settlement transactions are retained when a replacement transaction is created (older transactions are sent to a status of "Superseded"). "Keep One Record per Period" indicates that only a single settlement transaction is retained for a time period (older transactions are deleted when the new one is completed).
Valid Settlement Calculation Groups: A list of valid settlement calculation groups for settlement subscriptions of this type
Valid Recipients: A list of valid recipients for settlement subscriptions of this type
Communication: The outbound communication type used to create of outbound communications when sending the results of settlement transactions based on settlement subscriptions of this type
Refer to Configuring Settlement Units for more information about setting up settlement units and their respective dimension combinations, factors, and factor values.
