Interval Averaging Estimation
The algorithm estimates when the current Measuring Component is eligible. Estimation is performed only if all these conditions are satisfied:
The Measuring Component is interval.
The Measuring Component is linked to a Service Point or the VEE Rule's Estimate If Not Attached to SP field is set to "Estimate”.
The Percentage of Missing Intervals is less than the VEE Rule's Maximum Percentage Missing Intervals Threshold.
The algorithm will compute the Total Accumulated Consumption and the Total Number of Intervals using a variety of methods including scanning holidays, similar days of the week, or neighboring days. Once a set of valid comparison days are found then these are used as the basis of creating estimated intervals for the current IMD.
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-INTAVGEST Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-IntervalAveragingEstimation
