Maintaining Service Point Quantities
You use the Service Point Quantity portal to view and maintain service point quantities.
You can access the portal from the Main > Device Installation > Service Point Quantity. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Service Point Quantity: This zone displays the basic attributes of the service point quantity
