Reviewing Measurements for Reprocessing
When the Measurement Reprocessing Activity Types are configured as "Yes" in the "Approval Required?" field, then a To Do will be generated for user review. The To Do Type for this is set on the Activity Type as well (the configuration for this is covered in detail in the section for
Configuring Measurement Reprocessing in the Administration Guide).
This To Do provides an approval step for a user to examine the Measurement Reprocessing Activity and perform the following:
1. Determine if the multiplier change appears legitimate and accurate. Information on the type of change that occurred can be found on the Log tab for the Activity. If the change should be rejected, this can be performed using the Discard button.
2. Ensure that the period being examined for reprocessing (shown as the Activity Start Date and End Date) covers the period expected. If not accurate, the dates can be changed using the Edit button.
If all information on the Activity is correct, then press the Approve button to allow reprocessing to continue. Once the activity is finished, a list of the spawned IMDs will be displayed on the Activity screen.
Parent topic
