Reviewing and Resolving VEE Exceptions
All To Dos generated by a VEE Exception will link back to the Initial Measurement Data that originally failed to create the VEE Exception.
Users have a number of options for dealing with initial measurements with exceptions.
• After correcting the cause of the issues that triggered the exceptions, a user can reinitiate the VEE process for the IMD using the Perform VEE button.
• A user can Discard the initial measurement.
• A user can use the Force Complete button on the IMD in the scenario that they want to approve the exception and the measurement information in the IMD. Note: No VEE processing is performed on initial measurement data that is force completed. Regardless of the action taken by the user, the system will complete any open To Do Entries that created when the initial measurement entered the Exception state.
Refer to
About VEE for additional functional information.
Parent topic
