About Settlement Item Market Participants
Settlement item market participants connects a Market, Market Participant and Settlement Item together over a specified date range. Settlement item market participants can be created either via the Settlement Item Market Participant portal, or by adding a market participant to a settlement item via the Settlement Item portal.
Settlement item market participants are defined by the following:
• Settlement Item: The settlement item for which this settlement item market participant was created.
• Market Relationship Type: The market relationship (Distributor, Supplier, etc.) of the market participant and its role within a market.
• Start Date/Time: The start date/time for when the record is applicable.
• End Date/Time: The end date/time for when the record is applicable.
• External ID: An ID for the market participant used by external systems.
• Market Participant: The market participant associated with the Settlement Item, including an optional ID used by the market participant to uniquely identify the settlement item.
Parent topic
