Using the Service Order Trends Dashboard
This portal is used to display the Service Order Operational Dashboard.
You can access the portal from the Main > Dashboards > Service Order Trends Dashboard. Once you've selected this menu option, you're immediately brought to the initial tab of the dashboard.
• Orchestration Issues Trend: contains a stacked bar chart showing issues by category and Activity Type.
• Issue Distribution Over Time: contains a pie chart showing the distribution of activity issues over a range of days.
• Activity Success Trend: shows successful activities over a range of days.
• Activity Creation Trend: shows activities created over a range of days.
• Activity Completion Efficiency Over Time: shows the efficiency of activity completion over a range of days.
Parent topic
