External System
External systems represent external applications with which the Smart Grid Gateway will exchange messages or data. In the case of the Smart Grid Gateway adapters, external systems represent the head-end systems with which the adapters communicate.
An external system that represents the L+G Command Center must be present in your system. If this is not present in your configuration, add it, along with the following Outbound Message Types. Refer to the Oracle Utilities Application Framework documentation for more information about creating external systems.
External System - Landis+Gyr:
External System: LG
Description: Landis+Gyr
Outbound Message Types:
Description
Message Sender
D3-ADDMTRINV
Add Meter to Inventory
Message sender associated with the Add Meter to Inventory Outbound Message Type
D3-COMMS
Commission Device
Message sender associated with the Commission Device Outbound Message Type
D3-CONNECT
Connect Device
Message sender associated with the Connect Device Outbound Message Type
D3-DECOMMS
Decommission
Message sender associated with the Decommission Device Outbound Message
D3-DEMRESET
Demand Reset
Message sender associated with the Demand Reset Outbound Message Type
D3-DERDEV
Deregister Device
Message sender associated with the Deregister Device Outbound Message Type
D3-DISCONNEC
Disconnect Device
Message sender associated with the Disconnect Device Outbound Message Type
D3-DVCSTSCHK
Device Status Check
Message sender associated with the Device Status Check Outbound Message Type
D3-INITMRN
Initiate Meter Read by Meter Number
Message sender associated with the Initiate Meter Read By Meter Number Outbound Message Type
D3-INITMTR
D3-MTRADDNOT
Meter Add Notification Outbound Message Type
Message sender associated with the Meter Add Notification Outbound Message Type
D3-MTREX
Meter Exchange Notification OB MSG
Message sender associated with the Meter Exchange Notification Outbound Message Type
D3-MTRRMV
Meter Remove Notification
Message sender associated with the Meter Remove Notification Outbound Message Type
Note: The following apply to the above outbound message types*:
Processing Method: Real-time
Message XSL: D3-Request xsl (*use D3-DRRequest.xsl for the Demand Reset command)
Response XSL: D3-Response.xsl (*use D3-DRResponse.xsl for the Demand Reset command)
