| Web Service | Related BPEL Process | Description |
| CB_ServerService | ConnectDisconnect | This web service defines the return interface, the means by which the status is returned to the calling system. This web service is only be invoked by the head end system, not OUAF. Only the CDStateChangeNotification web method is implemented in the composite. The endpointURI format is: http://<EM_SERVER>:<EM_SERVER_PORT>/soa-infra/services/Sensus/ConnectDisconnect/CB_ServerService |
| CB_Server | OnDemandRead | This web service defines the return interface, the means by which the reading is returned to the calling system. This web service is only be invoked by the head end system, not OUAF. Only the ReadingChangedNotification web method is implemented in the composite. The endpointURI format is: http://<EM_SERVER>:<EM_SERVER_PORT>/soa-infra/services/Sensus/OnDemandRead/CB_Server |
| OA_ServerService | DeviceStatusCheck | This web service defines the asynchronous return for InitateOutageDetectionEventRequest for solicited responses. It is also used for unsolicited alarms. This web service is only be invoked by the head end system, not OUAF. Only the ODEventNotification, PingURL, and GetMethods web methods are implemented in the composite. The endpointURI format is: http://<EM_SERVER>:<EM_SERVER_PORT>/soa-infra/services/Sensus/DeviceStatusCheck/OA_ServerService |
| Smart Grid Gateway Command | AMI Adapter Business Objects | Sensus Web Services | Sensus Operations |
| Device Commissioning | D6-MeterAddNotification | MR | MeterAddNotification |
| Device Decommissioning | D6-MeterRemoveNotification | MR | MeterRemoveNotification |
| Remote Connect/ Remote Disconnect | D6-InitiateConnectDisconnect | CD | InitiateConnectDisconnect |
| D6-ConnectDisconStateChgNtf | CB | CDStatesChangedNotification (async reply) | |
| Device Status Check | D6-InitiateOutageDetection | OD | InitiateOutageDetectionEventRequest |
| D6-OutageDetectEvtNotification | OA | ODEventNotification (async reply) | |
| On-Demand Read | D6-InitiateMeterByMeterId | MR | InitiateMeterReadingsByMeterID |
| D6-ReadingChangedNotification | CB | ReadingChangedNotification (async reply) |
