Inbound Web Services
Inbound web services define the details of how messages are received from an external system. This includes incoming usage and device events, as well as messages sent from the Silver Spring Networks UtilityIQ application in response to a command request.
The following inbound web services must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating inbound web services.
Inbound Web Service Name
Description
D1-BulkRequestHeader
Bulk Request Header
D1-BulkRequestUpdate
Bulk Request Update
D1-BulkResponse
Bulk Response
D1-DeviceEventSeeder
Device Event Seeder
D1-DeviceStatusCheck
Device Status Check
D1-InitialLoadIMD
Used by OSB to instantiate an IMD
D1-PayloadErrorNotif
Payload Error Notification
D1-PayloadStatistics
Payload Statistics
D1-PayloadSummary
Payload Summary
D7-ConnectDisconnectResponse
Connect Disconnect Response
D7-GetStatusResponse
Get Status Response
D7-MeterReadResponseInterval
SSN - Meter Read Response (Interval)
D7-MeterReadResponseScalar
SSN - Meter Read Response (Scalar)
D7-PingJobResponse
SSN - Ping Response
Note: The following apply to all of the above inbound web services:
Message Options
Trace: No
Debug: No
Active: Yes
Operations
Operation Name: Same as web service name
Schema Type: Business Object
Schema Name: Applicable business object code
Transaction Type: Add
