| Business Object Name | Description |
| DG-ConnectDisconStateChgNtf | Generic - Connect/Disconnect State Change |
| DG-InitiateConnectDisconnect | Generic - Initiate Connect Disconnect |
| DG-InitiateMeterByMeterId | Generic - Initiate Meter Read By Meter ID |
| DG-InitiateOutageDetection | Generic - Initiate Outage Detection |
| DG-MeterAddNotification | Generic - Meter Add Notification |
| DG-MeterRemoveNotifcation | Generic - Meter Remove Notification |
| DG-OutageDetectEvtNotification | Generic - Outage Detection Event Notification |
| DG-ReadingChgNotification | Generic - Reading Changed Notification |
| Head-End System Flat File Field | Device Event Seeder BO Element | Comments |
| Transaction ID (from Header record) | External Source Identifier | This is the file name. |
| Device Identifier | External Device Identifier | |
| Event Name | External Event Name | |
| Event Creation Date/Time | Event Date/Time | |
| Device Type | External Device Type | This element has no real bearing on the device type within MDM/SGG. Its valid values include (although the element itself is free-form): Meter Collector Router |
| Service Location ID | External Service Location ID | |
| Communication Module Serial Number | External Communication Module Identifier | |
| Event Category ID | External Event Category | |
| Event Severity | External Event Severity | Valid values include (although the element itself is free-form): Alert Information |
| Status Value | External Status Value | This represents additional information that relates to the event itself. |
| Status Date/Time | External Status Date/Time | The date & time at which the additional information referenced above had occurred. |
