OSB Processing Terms and Acronyms
This section lists several terms and acronyms used throughout this chapter.
Term
Definition
AMI
Advanced Metering Infrastructure
CSV
Comma-Separated Values
FA
File Adapter. Oracle JCA File Adapter.
FP
File Parser, Java code that parses input file and generates Plain XML
GA
Smart Grid Gateway generic adapter
GFP
Generic File Processor, Java code that is invoked by FA. It communicates with FP
IMD
Initial Measurement Data
IMD XML
The final XML containing the IMD.
JAR
Java Archive
JAXB
Java Architecture for XML Binding
JCA
Java Connector Architecture
JDeveloper
Freeware Oracle integrated development environment for development of Java-based SOA and Java EE applications
JMS
Java Message Service
MDB
Message Driven Bean
SMDF
Service and Measurement Data Foundation
OSB
Oracle Service Bus
OUAF
Oracle Utilities Application Framework
Plain XML
An intermediate XML containing all of the values from the inbound file. It is necessary because OSB Message Flow can handle only XML.
PPS
Processing Proxy Service, OSB proxy service where the validation and transformation of Plain XML is implemented. It is necessary to catch errors that occurred before Plain XML is transformed to IMD or Device Event seeder structures.
RFD
Rejected File Descriptor, File containing information about a portion of input file that was a cause of error.
RPPS
Result Processing Proxy Service, OSB proxy service where processing of transformation result is implemented. It is necessary to catch errors that occurred after Plain XML is transformed to IMD or Device Event seeder structures.
SGG
Smart Grid Gateway
Weblogic
Oracle J2EE Application Server
WSD
Web Session Directory
XML
eXtensible Markup Language
XPath
Programming language for selecting nodes from an XML document
XQuery
Programming language to query XML.
