Overriding Parameter Values
Implementation teams may override the value of selected types of base provided zone parameters. The override parameter value field for base owned zone parameters is only enabled when the related zone type parameter usage is Zone - Override Allowed.
For multi-query zones, you may use the override parameter value to add custom query options to a base product owned zone.
Parent topic
