Editing Import Bundles
You can remove entities from an import when it is in Pending state. You can also change the sequence of entities and edit the generated XML.
To edit a pending import bundle:
1. Open the bundle in edit mode.
2. To edit the XML snapshot, click Edit XML. Edit the XML code as needed, then click Save.
Use caution when editing the XML to avoid validation errors.
3. To remove entities or change their sequence, click Edit. Make any necessary changes and click Save.
