How Are To Do Entries Created?
A To Do Entry may be created in the following ways:
• An
algorithm can create entries of a given type. Because the use of algorithms is entirely dependent on how you configure the control tables, the number of types of such entries is indeterminate.
• A user can create entries of To Do types that have a
Manual usage. Refer to
To Do Entries Created Manually for information about setting up manual To Do types.
For any base product process that includes logic to create a To Do entry, the system supplies a sample To Do type that may be used. Although the To Do types provided by the product are system data, the following information related to each To Do type may be customized for an implementation and is not overwritten during an upgrade:
Parent topic
