How To Substitute Variables In Text
You can substitute field values into a step's text string. You do this by prefixing the field name whose value should be substituted in the string with a %. For example, the message, "On %COMPLETION_DTTM this bill was completed, it's ending balance was %ENDING_BALANCE" contains two substitution variables (the bill's completion date / time and the bill's ending balance).
To substitute the value of an element from a data area you need to reference its XPath location as follows: %=XPath=%. If you want to substitute the whole XML node, not just the value, you need to reference it as follows %+XPath+%.
Only fields linked to the
current To Do and fields that reside in
temporary storage and
global variables can be substituted into a text string.
You can substitute fields that reside in the User Interface or Page Data Model by first moving them into temporary storage (using a Move data step).
You can also substitute field values into the verbiage displayed in
prompts using the same technique.
Parent topic
