Field Descriptions Shown
The language-specific, logical name of each field is shown adjacent to the physical column name in the data dictionary. You can enter an override label for a table / field's to be used throughout the system as the field's logical name. Here too it is the override label that is shown.
Note:Regenerate. You should regenerate the data dictionary after overriding labels. Refer to Application Viewer Generation for further details.
